Originally posted by Bigdomino I shoot an image in Raw and one using jpeg. The results seem to be about the same to me. What am I missing?
The difference is that you can edit the RAW file non-destructively in your software of choice. The changes you make to a RAW file are not actually changes to the file itself. They are only references to the changes you made. These references are stored by the editing software and applied to a JPG of the RAW file when you export it. The exported JPG file is what you then use as your finished image. The RAW file is always there, unchanged by the editing software, waiting for you to come edit it again and make another version.
If you were to attempt the same with a JPG file, every time you make a change, you are actually irrevocably destroying the original data. This degeneration accumulates and can result in an image that only gets worse, never better with successive edits.
If you just want the picture and don't anticipate any need to make changes, you can skip the whole step and shoot JPG in the camera. There are editing options in the camera that you can use beforehand that will tell the camera to generate the JPG to your specifications from the RAW file that is captured by the sensor.
