03-12-2014, 02:18 PM   #1
Pentax me super wind lever problem
Hi guys
My wind lever only goes half way and then stops like it's blocked. How can I fix that? And is it a major problem
03-12-2014, 02:31 PM   #2
jtkratzer's Avatar
If it's not working, for whatever reason, and you can't fix it yourself, Eric Hendrickson is your solution. www.pentaxs.com. He has three of my camera bodies right now.
03-13-2014, 08:01 AM   #3
FrankC's Avatar
Not to insult your intelligence, but I've seen it too many times not to mention it: Are you sure you're not at the end of the roll of film? This type of error happens when the user thinks that they've got a roll of 36 exp when they actually have a roll of 24.
03-13-2014, 01:01 PM   #4
Just1MoreDave's Avatar
A lot of that mechanism is accessible by removing the bottom plate. There are so many moving parts that it may be impossible to see one that's not moving correctly, but you might see something obvious. My camera repair technique is to have a working copy on hand, to compare with the broken one.
03-13-2014, 01:14 PM   #5
There is no roll of film In there at all. I did up some in to see if it would work but it still stopped half way
03-13-2014, 11:29 PM   #6
Dark Underlord
AquaDome's Avatar
There are many ME Supers with broken winders. Its a common problem. Fortunately, there are MANY more ME Supers out there. I would keep it as a parts camera for the next one.
camera, lever, pentax help, photography, wind, wind lever
Pentax P30 - Wind Lever Problem. nat.mitch Troubleshooting and Beginner Help 4 08-09-2020 04:20 AM
ME super wind lever problem Cat among the pigeon Pentax Film SLR Discussion 11 07-14-2015 06:28 PM
ME Super wind lever loose cafazucar Pentax Film SLR Discussion 31 04-11-2014 08:11 AM
Pentax ME Super - Aperture Lever Problem ioszhka Pentax Film SLR Discussion 9 02-10-2011 03:30 AM
Me-super rapid wind lever not returning properly Heldur Pentax Film SLR Discussion 13 10-10-2008 12:45 AM
All times are GMT -7. The time now is 07:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
