Originally posted by dansamy Mobile Skyline and Mobile River from Cochran-Africatown Bridge Mobile Alabama | al.com
This is about the best picture I can find, but the spot I have selected puts us over a bit from this perspective. We'll still have the port and the RSA tower and the hotel. The port has work mostly 24/7, so it should be lit up pretty much anytime we go.
And I think I've got my signature up to date now with all the shtuff I have bought off eBay...
Evening,
So, I took Mobile, Alabama and went to google maps and looked for an evening skyline view. I came up with map #1. It shows that it was taken down in the dock area across the river. I figured that was probably not too accessible, so I used google earth and its streetview to "drive" along Dunlap Drive, the frontage road that runs in front of Austal, and found what looks like a reasonable location, just south of the plant. I then went to
and dropped the location pin at the area and had it calculate sun and moon times and angles. It looks like you can get a sunset real near the large buildings downtown, along with lots of blue hour. So that is map#2. Then the third image is from google earth showing the view during the day. I measured some distances using google earth's tape measure, then using some geometry, it looks like a 28mm focal length should capture everything at the widest and probably 70mm at the narrowest. I just don't know where all the buildings are actually located downtown so as to be able to measure accurately - so I just estimated where I thought they might be. Bottom line, your zoom would work really well for this location.
As for times this weekend
- Sat 15.03.2014 sunset 19:02 @ 269° at 19:26 and twilight lasts for 24 min
- Sun 16.03.2014 sunset 19:03 @ 269° at 19:27 and twilight lasts for 24 min
You have a lot of lenses that would work really well... essentially all of them would work for various views
DAL 18-55
DAL 55-300
DA 35
DA 50
Sigma 28-105 2.8-4
F35-70
FA28-70 f/4
Tamron 17-50/2.8
If need be, you could zoom in and shoot over the possible uninteresting foreground and then stitch the images together in a panorama.
Hope that helps....
