It depends on the coating and the cleaning technique. A few examples:
- It is almost impossible to find a Canon rangefinder lens that does not have cleaning marks. Ditto for former Soviet Jupiter-9 rangefinder lenses. Most of these marks are only as deep as the coating, though I have seen a few where little of the original coating remained. These are vintage lenses with early coatings.
- I have ruined more than one filter in my youth after applying the "clean" corner of a t-shirt. Thankfully, no lenses to date.
- I have seen terrible cleaning marks on used lenses (both front and rear elements) that looked like someone had applied steel wool. Yes, I would suggest that the scratches effected image quality. Remember, it is the angle of the glass surface that determines the refraction. Make a scratch and a portion of the light goes the "wrong" way. Remember too that the coating is there to provide more efficient light transmission and less reflection.
What do I do?
- I (almost*) never do dry cleaning...no, not even a microfiber cloth
- I usually use Windex sprayed on a frayed piece of paper toweling and used as a flexible "brush" to apply the solution to the face of the lens
- I follow with a clean, soft cotton rag (scrap of old t-shirt) in a light circular motion
- I do not apply pressure or "scrub"
- If there is still stuff on the lens, I repeat the above
The main issue is mineral dust that is probably harder than the glass and/or the coatings. It can be embedded in a cleaning cloth. Not good.
Prevention?
- Use your lens caps and keep the caps themselves clean
- Don't let dirt accumulate in your camera bag
- Your lens hood is the best defense against prints from errant fingers
- Don't sneeze or cough on the camera
* Yes, almost. I do keep a "known clean" microfiber chamois in my bag and have been known to use it lightly in combination with a lot of condensed breath as a lubricant. The microfiber does a good job of wicking oils and other liquids off the lens surface.
