Originally posted by clackers Actually, PSUs are cheap components in otherwise expensive computers and can be responsible for quite frustrating and/or intermittent errors, especially if dust has built up over time. The problems can even resemble those of bad RAM.
You are so right, I did not realise this either but the computer parts supply vendor I purchased the PU from told me some real horror stories. He said I was lucky to have discovered the faulty (worn out) PU in time because a little further down the track It could have even fried some parts including HDDs.
Not saying the OP should immediately replace the PU as indeed it may not be the culprit but having it checked out wouldn't hurt
Greetings.
