As of yesterday all of a sudden my K-x is randomly experiencing major shutter lag about every 5th to 10th shot. That's with new, fully charged batteries and a couple of fairly fast new San Disk cards. I've tried changing out the batteries, and the cards, changing lenses, no effect. It still happens even in bright light outside and even on full auto. The sensor is fairly clean, used the blower to make sure, so no problems there. I have put some wear and tear on it but not as much as I thought actually. Shutter count is at like 11K. The camera did go flying a while back, when I nearly fell in a pool shooting, but it wasn't damaged at all.
I was lucky. I caught it right in my hands on my lap. It never hit anything. That was over a year ago and it's been working just fine till yesterday. I went to do a few head shots with it and it just started doing that. I've never had a shutter fail so I don't know if this is what it's doing. When the bad *ist I bought died it just quit working completely. I'm wondering is this what happens when a shutter decides to blow? Does it just randomly freeze up every so often until it just finally dies? Please tell me not! I don't want this right now, I really DON'T! :P
I'm just wondering how worried I should be? I'm not working a lot. I'm doing like 5-6 small jobs a month right now. I'm making the rent and that, but just barely. Business has really sucked since Dec, but if this camera goes it's going to cause me to have to quit working for a month or two until I can afford another body. I just don't have the room on my credit card just now to charge a new one and not much in the Hello Kitty bank either.
Stupid 3K bathtub repair and my roomie moved out, so now I'm paying 2X the rent. I do have to wait till at least July. If it does go I'll have to resort to using the M43 camera (or film) and that probably won't fly very well with my snobby clients who totally expect a DSLR. I've got a credit card limit increase coming in July for sure. My CU told me so. I can grab a sub $500 body then if I have to, but until then I'm going to have to baby this one and hope it holds out till then.
I'm just sitting here wondering if this is a sign of impending doom? I didn't expect it. The K-x has never given me a lick of trouble before. It's been a very dependable little DSLR. I was going to give it to my niece this Summer but that might not be a viable option now I guess. I can't afford to just let it go and send it off to be fixed, and anyway I doubt that would be cost effective anyhow. As little as K-x's are going for now it would probably cost me more than just grabbing another used camera in a month or two would. Not worth it.
Info? I could use a little advice here. Should I try a hard reset? (It has the latest firmware.) I figure I'll just keep using it, just for work, and hope for the best till July, but I am a bit worried that it might blow out on me before then and cost me some work. Anyone here experience shutter failure and if you did is this what happened?
This is why it's always a good idea to have TWO bodies if you're going to shoot for a living, and why I am going to have to go there as soon as I can. I've had so many people ask me why I want 2, but I think this situation pretty much illustrates the need. This camera goes and I am a bit screwed. You are unless you have a backup, which is why by this time next year I will have TWO DSLR bodies, not one.
Just out of curiosity I checked the exif on some shots I did to test my lenses and what I'm seeing is that it says I'm going to long bulb like exposures when I'm only trying for normal exposures not settings like I'd use for a night shot. I'm not changing it to anything. The camera does it whether I am in full auto or using manual. It will take me from a normal exposure to that without me touching the dial, and no matter what the lens settings are. I'm shooting 50mm at 1/60 or 1/30 or whatever and I'm getting long exposure times when I'm just taking more than one shot of the same thing, same lighting, lens settings, camera settings etc. The first 5 or 10 shots will be fine, but then the next one will be totally screwed up. Then it will be fine again for 5 or 10 shots then screw up again. It's not just a little random blur like I just missed my shot focus. I'm talking major overexposure, lightning effects, the whole picture being totally messed up and the shutter lags. You can hear it stalling. It catches, then releases, but it takes a while, like the camera is shooting at night in bulb mode, only it's not.
