03-23-2014, 04:49 PM   #1
Shanti's Avatar
Best way to remove sensor grease/oil?
Hi,used a lenspen brush to get some dust off & it left a greasy film? from where I don't know..had used it before with no bad effects, but what's the best way to remove grease /oil?? It can be from around the sensor frame as well. From what I see the Pentax cleaner is only for dust. Is the Pentax sensor sensitive to certain wet cleaning products?
K5II camera
Thanks for any help
COOLPIX P7100  Photo
COOLPIX P7100  Photo
03-23-2014, 05:37 PM   #2
fgaudet's Avatar
Sensor Swabs (google it) always worked for me. But if there is dust, you risk scratching your sensor, and this would be baaaaad.
Check with your local camera store to see if they professionally clean sensors, sometimes it's worth it.
Here on BH... You need type II for Pentax
http://www.bhphotovideo.com/c/product/242758-REG/Photographic_Solutions_SS2B...ab_Type_2.html
And you will need their cleaning solution too
Or get some already "wet"
http://www.bhphotovideo.com/c/product/572883-REG/Photographic_Solutions_PE2C...l/prm/alsVwDtl
The first few tries, you may need more than 4 before you get the technique right
03-23-2014, 05:47 PM   #3
I recall reading that around the edges of the sensor, there is supposed to be some sticky stuff there to capture dust that is loosened by the built-in ultrasonic cleaner. Otherwise the loose dust would just keep getting tossed around to fall back on the sensor. I don't have any personal experience but this sounds reasonable to me. So anyhow, you need to stay away from that area.
03-23-2014, 08:55 PM   #4
Shanti's Avatar
from what i read Visible dust or Eclipse are the best solutions to use,anyone have experience with these? can get from UK easily
03-23-2014, 09:13 PM   #5
fgaudet's Avatar
QuoteOriginally posted by Shanti Quote
Eclipse
Eclipse is the cleaning solution used (made by) Sensor Swab. I had good results with it but it proved to be more difficult to clean than expected, my first two tries made it worst than it was before. The third one was the charm. I guess it takes a bit of practice to get the swiping motion right.
dust, pentax, pentax help, sensor, sensor grease
Best way/product to remove sticky stuff from zoom ring? LowVoltage Pentax SLR Lens Discussion 9 10-02-2013 06:06 PM
Best way to protect LCD screen? *Rich Pentax K-5 6 10-15-2012 06:26 PM
Using pocket air ionizer to remove static charge in sensor GibbyTheMole Pentax DSLR Discussion 10 08-18-2012 04:08 PM
Dead K10D: How to remove the sensor? feralryan Pentax DSLR Discussion 4 05-07-2010 06:53 AM
[joke] Revolutionary way to clean your sensor, the Pentax way ! thibs General Talk 9 02-13-2008 03:42 AM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
