03-27-2014, 09:54 AM   #1
Help repairing "Memory Card Error" on K10D
Hello,
New to the forum, unfortunately I couldn't find a direct answer to my problem. I get the "memory card full" message with any SD card I try. Then I decided to open the camera and see what's going on. Sure enough, I found the connector that bridges the PCB to the SD reader board, ripped off the main PCB. So, now I have a microscopically small, partially damaged connector, with a main board that has broken tracks which I can't repair.
Has anyone been successful in repairing this? The main PCB is perfect other than this connector. I'd like to know if I can get a new connector. Otherwise, looks like a new PCB board (not sure if it's worth it at this point, or if it's even still available).
Thanks,
Evan
FinePix F20  Photo
FinePix F20  Photo
FinePix F20  Photo
03-27-2014, 10:46 AM   #2
tomwil's Avatar
QuoteOriginally posted by EvanBand Quote
Appears this connector got ripped off the main board either by a camera drop, or pulled off while disassembling.
If the connector can be resoldered back onto the main board, trace lines can sometimes be repaired either by painting new conductive material, or running thin wires.
03-27-2014, 11:16 AM   #3
Thank you Tom for the quick response. And you're right, the camera was dropped, and that caused the connector to rip off.
What you suggest, is exactly what I'd like to do, maybe trace the lines. The problem is that they are so small, I can't even see them. I guess I might have to invest in a 10x magnifier, and see things better.
07-06-2017, 02:18 PM   #4
hey did you ever get the camera to work? did you solder the board?
board, card, connector, pcb, pentax help, sd
*ist DS "memory card error" - card won't format WMBP Pentax DSLR Discussion 6 04-05-2016 04:39 PM
K-30 and UHS1 card "Memory Card Error" pavanbabut Troubleshooting and Beginner Help 18 12-29-2013 05:10 PM
K20 "Memory Card Full" Error message FHPhotographer Pentax DSLR Discussion 2 02-10-2012 10:22 AM
Memory card "card not formatted" error mickc Pentax Camera and Field Accessories 7 07-12-2011 08:49 PM
"memory card error" after K10D fell: prognostic? nicolas1970i Pentax DSLR Discussion 3 07-07-2009 12:03 PM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
