04-01-2014, 04:56 PM   #1
problem attaching lens
My K30 arrived today. I unpacked all the stuff that came with it and went to attach the lens (18-55) which came with it. following the directions, I lined up the red dots and the lens would not turn. I tried everything...applied moderate pressure, no pressure, a slight gap, tight to the body. Nothing. Very frustrating and since I purchased it on amazon, returning it will be a pain. Is there something stupid I am missing?
dave
04-01-2014, 05:05 PM   #2
To be honest, I've never heard of anyone having issues mounting the kit lens before, which means that hopefully there's nothing wrong with your gear
Can you post a photo of the back of the 18-55mm lens as well as the lens mount on the camera? We should be able to tell just from that.
The normal procedure for mounting a lens is to align the dots, push the lens all the way in so that it's flush with the camera mount, then turn your hand clockwise so that the center of the lens lines up with the prism housing/flash on your camera.
04-01-2014, 05:23 PM   #3
pictures
I have attached two pictures (I hope)
04-01-2014, 05:34 PM   #4
try pictures again
the previous try didn't work. i will try posting a link to the pictures https://plus.google.com/u/0/photos/104842630099472816391/albums/5997482457348772897
04-01-2014, 06:02 PM   #5
yep it is! A couple of things seem a bit odd. First of all there a three little screws on the lens that have a small piece of metal between the screws and the lens body causing them to be raised just a little. Also there is a small metal flap on the camera body that is bent down. it is located just under the red dot. I don't know if this is normal or not.
04-01-2014, 06:03 PM   #6
chromo's Avatar
Could be an olympus lens. From memory they will fit into the mount but not turn.
---------- Post added 2nd Apr 2014 at 12:07 PM ----------
Is this the kit ?
Amazon.com: Pentax K-30 Weather-Sealed 16 MP CMOS Digital SLR with 18-55mm Lens (Black): Camera & Photo
04-01-2014, 06:12 PM   #7
QuoteOriginally posted by chromo Quote
Is this the kit ?
Not the precise kit, but pretty much identical. the lens is a Pentax
04-01-2014, 06:17 PM   #8
Look for some bits and pieces in either the camera mount, or the lens mount. There could be a broken piece of plastic, one of the items might have been installed at an angle instead of flat etc. All in all, I think that it would be fair to have it replaced by mail.
04-01-2014, 06:17 PM   #9
fgaudet's Avatar
The
QuoteOriginally posted by nodders Quote
Do you mean this (see photo)... If yes, this is normal, it's the grounding contact for the lens.
And from your pictures, your 18-55 is damaged, it's missing the contact pins and there is visible damage around the screws. IMO this lens was dropped while attached to a camera...
PENTAX K-5  Photo
04-01-2014, 06:18 PM   #10
How is returning on amazon a pain btw? You just put it into the box it came in with a printed label. It's very easy.
04-01-2014, 06:23 PM   #11
fgaudet's Avatar
And this is what the back of your lens should look like, I marked up the area where your lens shows damaged or missing piece (screw-drive, contact pins)
PENTAX K-5  Photo
04-01-2014, 06:27 PM   #12
patrick9's Avatar
It appears that the lens has been messed with. I don't see the screw drive in it's hole nor are the balls for the contacts apparent in the shot . There is also damage around the screws Here is a shot of the back of my 18-55
P.S.
Fgaudet posted while I was typing. He may have it correct in being a dropped lens On camera ,as the damage would be consistent with the damage shown.
04-01-2014, 06:30 PM   #13
thanks so much - looks like a return to me. thanks for all your help!
04-01-2014, 07:04 PM   #14
Looks like someone else took advantage of Amazon's easy return policy and returned their destroyed lens. Does the serial number on the lens match the one on the box?
04-01-2014, 08:17 PM   #15
I think elliott nailed it. Good thinking.
camera, lens, pentax help, photography, pressure
Attaching 43mm filter to 21mm lens hood CPS Visitors' Center 7 09-20-2012 02:02 AM
Tamron Adaptall-2 lens attaching 2X converter littledrawe Pentax SLR Lens Discussion 9 05-03-2011 10:39 PM
problem attaching lens to camera double d Troubleshooting and Beginner Help 14 03-18-2011 07:44 PM
Attaching M42 adapter permanently to a lens Tim_R Pentax SLR Lens Discussion 9 10-07-2010 05:45 AM
Attaching filter on film lens, is it usefull? kyrios Pentax SLR Lens Discussion 4 04-09-2007 01:12 AM
All times are GMT -7. The time now is 06:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
