04-04-2014, 01:39 PM - 1 Like   #1
K David's Avatar
K-r Crazy Shutter
I picked up a K-R with 14,000 actuations. Sometimes it randomly has what I call crazy shutter. sometimes the shutter just starts moving at the high-speed framerate, but it's not taking any pictures. It's also not sustained and comes in and out. I reset the settings and updated the firmware from version 1.0 to the most recent 1.15. It's less frequent but still happens. Also, I've noticed it happens more in AV mode than other modes (but can happen in any mode). Has anyone experienced this? Is there an easy fix?
04-04-2014, 01:42 PM   #2
Na Horuk's Avatar
Um, I think it might be related to the battery. Maybe you can try another one?
04-04-2014, 02:10 PM   #3
Check out the forum threads on "mirror flopping". Are you by any chance experiencing this with a M42 lens??
04-04-2014, 02:25 PM   #4
K David's Avatar
I'll try some AA batteries when I get home. I ordered a new battery, but it hasn't arrived yet.
It's happened with the kit DA 18-55, SMC-M 50mm 1:1.4, and Olympus OM 28mm f2.8. This camera was behaving this way before I mounted the Adaptist PK+MM mount.
---------- Post added 04-04-14 at 02:26 PM ----------
Oh, and once in a long while the mirror does not go all the way back down (only about 85% of the way) until I unmount the lens.
04-04-2014, 04:07 PM   #5
K David's Avatar
I tried the holding the aperture trick and removing the battery. The first time, it did not work. The second time, it seems to have. Everything on the aperture linkage assembly appears to be correct, based on photos in the other threads. Thank you very much for the links. Hopefully, the camera will be okay.
05-05-2014, 12:48 PM   #6
franco64's Avatar
QuoteOriginally posted by K David Quote
I have a similar problem but apparently more serious because my shutter is completely blocked, k-r 2 years and 4 months old; I don't know what to do.
Franco
10-27-2014, 12:56 PM   #7
I am having this same "crazy shutter"same problem with my K-r whether I use the stock 18-55 mm lens or the 55-300 mm zoom lens. After taking 3-4 of pictures the back screen goes blank (no picture settings showing) and the shutter goes into high speed frame rate without taking pictures. I have found that if I push the LV button to put picture view on the back screen the shutter continues in high speed rate for a few more seconds and then the screen all of a sudden goes into live view and I can then take pictures again. Any suggestions?
10-27-2014, 01:29 PM   #8
QuoteOriginally posted by Rfouts51 Quote
Start saving for a replacement camera? This is repairable, but the cost is close to that of a new K-50 body.
k-r, mode, pentax help, shutter
<5000 shutter clicks, K-r bit the dust timmijo Pentax K-r 19 04-15-2013 07:27 PM
Ok crazy question regarding k10d battery vs. k-r battery dmbaile2 Pentax DSLR Discussion 2 08-05-2012 02:32 AM
Pentak k-r shutter problem! Stephy.correa Pentax K-r 8 07-28-2012 12:17 PM
K200D shutter gone crazy Steve B Visitors' Center 3 06-11-2012 11:22 AM
All times are GMT -7. The time now is 08:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
