04-06-2014, 08:17 AM   #1
jpgs off non- formatted card
First time ever a new 64gb card I did not format. Pictures are on card I can scroll and see them but
can not find a way to get them off the card, all devices want to format the card first any help would be greatly appreciated.
Thanks Joe
04-06-2014, 08:21 AM   #2
jatrax's Avatar
Does your operating system support the newer cards? Make sure you have all updates installed. If so, then possibly your card reader needs updated drivers or does not support the newer cards.
04-06-2014, 09:03 AM   #3
Otis Memorial Pentaxian
That is what I suspect. To the OP: Are you able to copy the files across using a USB cable from camera to computer?
04-06-2014, 10:10 AM   #4
Joe
Tried to use usb cable from my k500 same thing computer want to format card in camera. Thanks Joe
04-06-2014, 10:10 AM   #5
jhaji's Avatar
The card was probably pre-formatted as the exFat file system. Check whether your OS supports it.
04-06-2014, 10:17 AM   #6
jatrax's Avatar
Not that it helps now, but a good rule of thumb is to always format a new card in the camera before using it. I format any card I put in the camera as a first step. It's faster than deleting images
If no other solution turns up you might see if you can use another computer to copy the files from the SD card to a usb drive or something so you can get them on to your computer.
04-06-2014, 10:37 AM   #7
So true! And with the safety advantage of having a freshly formatted card at the start.
04-10-2014, 09:39 AM   #8
bobphoenix's Avatar
This may sound very dangerous (and it is, a little) but you'll need to do a "quick format" to FAT32 and download and install a copy of "Pandora" (the image recovery software, not the music streaming program...)
Pandora will recover post formatted disc files, but it can not recover over written files... So, you'll have to save your recovered files to a different disc than your SD card...
Just make sure you do a "Quick Format" and not a full format and you should be able to recover everything...
Cheers,
Bob
card, format, pentax help, trouble 64gb card
memory card demands to be re-formatted every time mallory Troubleshooting and Beginner Help 27 01-06-2014 04:30 AM
K10D "card not formatted" even after formatting. johnman Troubleshooting and Beginner Help 2 06-27-2013 08:11 PM
K7 formatted SD card not recognized winkler Troubleshooting and Beginner Help 1 05-28-2013 07:12 PM
Memory card "card not formatted" error mickc Pentax Camera and Field Accessories 7 07-12-2011 08:49 PM
All times are GMT -7. The time now is 12:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
