04-13-2014, 11:25 AM   #1
minahasa's Avatar
K-x Eyepiece/Viewfinder Replacement
I gave my K-x to a friend a few months back, and now it developed that misty, murky Eyepiece/Viewfinder problem. From some thread I bumped into, it seems the only cure is replacing it. Anyone know where exactly I can buy this thing?
04-13-2014, 01:12 PM   #2
Assuming you been keeping silica gel in with your camera, I'm guessing it's just residue, and not moisture? If so, it probably doesn't need to be replaced, just sent off to a Pentax center to be cleaned...
04-13-2014, 03:23 PM - 1 Like   #3
Here is the post with the info, Only change from the istd is the outer frame is held on by 2 screws under it. You have to remove the back to remove them, there is a flat cable
to the back that is plugged on to the main board, it will just pop off and just press it back on afterwards.
Sequence is remove bottom, lift off top then remove back. Use a small screwdriver to take out the old lens and press in the new one no need to remove
the assembly. The small tabs on the side go down .
Same part# for all the cams , 0076570-L7
https://www.pentaxforums.com/forums/114-maintenance-repair-articles/102950-is...placement.html
k-x, pentax help
K-x replacement? moshepupkin Pentax DSLR Discussion 26 12-31-2013 03:58 AM
pentax k-r viewfinder ( eyepiece rear lens ) scratched leenaddict Pentax K-r 3 10-25-2013 08:25 AM
K-5 viewfinder eyepiece? Bcrary3 Pentax DSLR Discussion 4 04-24-2013 12:43 PM
Replacement eyepiece for viewfinder (K5) FrancisK7 Troubleshooting and Beginner Help 3 07-09-2012 05:46 PM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
