04-17-2014, 11:42 AM   #1
Meter scale on K200D
Hi I am new to the forum. I have a K200. Where would I find the meter scale? Not sure if I am asking it correctly. I am taking a course and the other cameras show a sliding scale on their display screen. Is it on the lower right when you are looking through the view finder once you partially hold the shutter button?
04-17-2014, 12:07 PM   #2
QuoteOriginally posted by Gracerog Quote
That's where it should be, are you in M mode? I believe in other modes the camera will just indicate the exposure compensation setting numerically, though I'm not 100% as it's been a while with that particular model.
04-17-2014, 12:41 PM   #3
The K200D does show a numeric meter scale (no sliding graphics) in manual mode on the right bottom of the viewfinder and also on the right bottom of the top display. It shows only values in the range of -3...+3 (for <-3 or >+3 it will stay at this value).
It is shown in M mode only and (depending on your settings) replaces the display of the actual ISO value.
In some other modes there will be the valid exposure compensation value instead. In this case, as long as you press the OK button, this will change to another, configurable value. I have set this to show the estimation of the number of pictures the SD card can still store.
meter, meter scale, pentax help, scale
Hyperfocal Scale on APS-C godwinaustin Photographic Technique 21 01-25-2013 03:16 PM
Distance scale on Af 540 FGZ vorstem2 Pentax Camera and Field Accessories 14 05-31-2012 04:54 AM
How to use the distance scale on lens. jpeldrid Pentax SLR Lens Discussion 12 04-21-2012 10:36 PM
K200D Battery Meter Problem Zerreth Pentax DSLR Discussion 34 10-25-2009 10:06 AM
K200d - Meter Operating Time Tedi Troubleshooting and Beginner Help 4 05-25-2009 08:43 PM
All times are GMT -7. The time now is 05:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
