04-18-2014, 12:32 PM   #1
K-r, mirror is not going up, no Live View either
Hi everyone,
just before holiday trip my K-r got broken. Wonder if this can be fixed at home or I have to search for camera specialist.
Symptoms are as following:
- When I press on shutter button there is a sound like internals are trying to adjust aperture and raise the mirror, but nothing actually happens.
- When I go to Live View mode, the same sound but nothing happens, mirror is not up.
- When I use Sensor Cleaning Mirror Up feature, nothing happens too.
- This is constant behaviour and does not depend on a lens attached. The same happens also without a lens.
- Some time ago K-r started to do mirror flopping with old K/M lenses, so it seems related also given K-r got broken having M135 lense attached.
Any ideas what is this? :|
See video here:
04-19-2014, 06:58 PM   #2
QuoteOriginally posted by d1pr3d Quote
Hi everyone,
See video here: Pentax K-r mirror/shutter issue - YouTube
"Broken" is too vague a designation. Did you drop it on the ground? This is the strangest sound I have ever heard come out of a camera. Although I doubt that I can help you, I would still be interested in knowing how this problem occured, considering that I myself am a mostly happy owner of the Kr.
If you didn't drop it, reset the camera, reinstall everything, and make sure that you have the latest needed firmware.
04-20-2014, 12:22 AM   #3
I am happy K-r owner for 3 years and 35k actuations already. Even had no plans to change it.
It just happened while shooting in a field, no drops, no hits, nothing. Just switched to this behaviour. As I mentioned, there was "mirror flopping" issue before with K/M lenses and this time I had M135 on.
I will be in London next week and will try to bring it to specialist (it is not that easy to find one here where I am in the middle of nowhere during global Easter holidays
Thus will post back if will get any valid answer.
Thanks anyway. Might be worth update firmware, hm..
04-20-2014, 12:10 PM   #4
If you need parts I have a K-r body expressly purchased for use as spare parts (I need the mirror and the casing)
04-20-2014, 12:18 PM   #5
QuoteOriginally posted by marcusBMG Quote
Thanks Marcus, will keep in mind.
12-19-2016, 08:27 AM   #6
Same problem with k20d
I have almost the same problem, the noise is exactly the same just that my camera is working really really slow. I didn't drop it or something it just stopped working.
Did you figure out a easy fix?
Thank you.
attached, k-r, lens, live, mirror, mirror issue, pentax help, shutter, sound, view
Locking the mirror during Live view shooting mtux Pentax DSLR Discussion 20 03-06-2015 10:45 PM
Live View-Mirror Position Den Pentax K-5 3 09-30-2013 06:38 AM
Macro No it's not here either! eaglem Post Your Photos! 4 07-05-2013 07:16 AM
K-r : Live View focus, AF & manual madbrain Pentax DSLR Discussion 6 06-02-2012 11:55 PM
Problem with k-r live view eldela1590 Pentax K-r 2 07-28-2011 12:45 AM
All times are GMT -7. The time now is 07:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
