04-18-2014, 03:17 PM   #1
chromo's Avatar
Tab resolution
Just wondering if anyone else had this issue and found a solution or is it just the way it is and nothing can be done about it.
If using my K-5 + Toshiba air card + Galaxy tab 3, 8" ... the photo displayed on the tab is not very good resolution.
04-19-2014, 08:44 PM   #2
Banned
Did you accidentally change the capture resolution in the menu? I would think the Galaxy should receive whatever the camera was putting out unless there's some sort of interference being picked up.
04-20-2014, 12:09 PM   #3
Whatever the resolution sent has been, it will not be identical to any display resolution (there are rare exceptions not applying to your case), and neither the dynamic range nor the colour resolution will be met by the display specs.
So, in all 3 aspects it will be interpolated by routines of your viewer program. The quality of the mathematical routines will decide how near to the real thing the displayed picture will be.
Could you try to use/install another viewer?
EDIT: Could it be the embedded thumbnail is used by the Galaxy program?
04-21-2014, 07:22 AM   #4
chromo's Avatar
QuoteOriginally posted by Al_Kahollick Quote
If you mean the cameras resolution then no. I always use max res.
---------- Post added 22nd Apr 2014 at 12:25 AM ----------
QuoteOriginally posted by RKKS08 Quote
The Galaxy program is a Toshiba app specifically designed for the Air Card. It doesn't have any resolution options.
display, galaxy, pentax help, program, resolution, tab, viewer
Bent tab on extension tube. Mr_Radzins Pentax Camera and Field Accessories 5 08-21-2013 06:17 PM
sd cards lock tab fell off adwb Troubleshooting and Beginner Help 7 11-28-2012 11:01 PM
Samsung Germany bundles NX20 with free Galaxy Tab RKKS08 Non-Pentax Cameras: Canon, Nikon, etc. 2 09-05-2012 10:11 AM
MX shutter lock tab missing. PollitowuzHere Pentax Film SLR Discussion 3 06-10-2011 08:32 AM
Thread Links - Open New Tab rormeister Site Suggestions and Help 6 08-09-2010 06:10 PM
All times are GMT -7. The time now is 07:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
