04-20-2014, 06:32 PM   #1
K5 issue
My trusty and much loved K5 seems to be developing what I think might be a wear issue. I'd be interested in hearing if I'm the only one it's happened to, and if there is a solution.
The problem appears as a flashing on the LCD in areas such as Time, Manual focus/Auto focus and focus pattern (all together). It wanders through different numbers looking like it can't settle on any particular combination.
It'll happen on different lenses and with different cards.
The only way it stops is by giving the lens a slight twist anti-clockwise (when viewed from the back). Nudging it clockwise brings back the flashing.There's no play, or slop, in the bayonet fitting that I can feel but I'm thinking there must be some connection that is right on the limit.
So... any clues?
Camera is 3 years old but well cared for and working fine in every other respect.
04-20-2014, 08:04 PM   #2
Have you tried cleaning the lens contacts? It could just be a connection issue.
04-20-2014, 08:47 PM   #3
A good suggestion Adam but yes, I clean regularly.
I'm using Servisol Electronic Cleaning Agent sprayed onto cotton buds, wiping over the camera and lenses where they connect. I don't think this is the problem (but I could be wrong).
I did forget to mention that the Auto focus is also affected by this problem - works when you tweak it anti clockwise and stops when you tweak the other way. Tested it on a few lenses with the same result.
Thanks again for the suggestion.
04-20-2014, 11:10 PM   #4
adwb's Avatar
Sounds like service issue, something inside has ether come loose or is busy failing
focus, issue, k5, pentax help
K5 wireless flash issue DougLee Flashes, Lighting, and Studio 3 10-20-2013 09:56 AM
K5 iis - Compatibility issue with Yongnuo 560 or hotshoe issue? maxk7dish Pentax K-5 2 10-02-2013 06:43 PM
K5 IIs Issue chrisan Troubleshooting and Beginner Help 7 08-12-2013 09:55 AM
Photodetector issue on k5 saumendra Troubleshooting and Beginner Help 12 05-04-2013 11:15 PM
Pentax K5 Video Issue mikeyahngelo Troubleshooting and Beginner Help 2 01-26-2013 12:50 PM
All times are GMT -7. The time now is 10:28 PM. | See also: NikonForums.com, part of our network of photo forums!
