Originally posted by lotech Hi there,
I was overjoyed when I read an article about deactivating the SDM on the lens to enable screw drive focusing, thought I could give my handicapped 16-50 a try, but then disappointed that the process requires a camera flashrom programming, I don't want to alter my new K3, so that I can still use SDM on the same lens at later time. I wonder if masking the lens contact can do the trick as well, any idea ?
You are not modifying the ROM of the camera, but of the lens. So once the lens has been re-programmed, it will work on any camera. The problem with the K3 is we have not yet learned how to put it into debug mode so that we can use it to modify the lens EPROM. But the process posted does not affect the camera's firmware in any way, only the lens. I borrowed a K100D to fix my DA*16-50 and have used it successfully on a K5, K30 and now, my K3.
