04-25-2014, 05:33 AM   #1
Focal lenght set up for analog zooms
Hello
I've purchased a PENTAZ A 35-105 f3.5 lens. Mounting it on my K3 it asks me to indicate the focal length of the lens. What's the suggested/best length shoud I provide ?
Thanks for help in advance.
Max
04-25-2014, 05:42 AM   #2
bluenose's Avatar
This is for the K-30 but it should hold true for the K-3. Using K-30 With Older Lenses | Ricoh Imaging Support
The last paragraph reads:
"The Input Focal Length screen will appear. Use the rear e-dial to select a focal length which is closest to the focal length of the lens you are using. If you are using a zoom lens, choose a focal length close to the midpoint of the zoom range of the camera. Press the OK button when you have made a selection."
Regards
04-25-2014, 09:49 AM   #3
QuoteOriginally posted by MaxCoFoto Quote
Hello
Max
You'll get the best results if you enter the focal length you'll be using most. You can always change the focal length setting later via the menu.
analog, k3, length, lens, pentax help, zoom
645 lenses on K-mount focal lenght Szenario Pentax DSLR Discussion 5 03-08-2014 06:01 PM
Focal lenght comparison with Teleconverter Scootatheschool1990 Pentax SLR Lens Discussion 7 05-10-2013 12:56 PM
manual lens macro focal lenght question Frank Bowler Troubleshooting and Beginner Help 5 12-10-2010 10:23 PM
How do you set 125mm focal lenght in K10D? FrancisK7 Pentax DSLR Discussion 3 08-29-2008 03:55 PM
Right focal lenght for shake reduction on s-mount lenses uPiX Pentax SLR Lens Discussion 13 01-31-2008 07:39 AM
All times are GMT -7. The time now is 10:23 AM. | See also: NikonForums.com, part of our network of photo forums!
