Originally posted by bkpix Yep, heat distortion. This is why astronomers don't use their telescopes from inside heated buildings to look out at the night sky -- the gradient between the warm room and the cool night air causes distortion where the light travels from denser (cool) to less-dense (warm) air, much the same way light bends when it hits the (dense) glass of a prism.
This can even happen simply by taking the camera from a cool environment to a warm one, or vice versa. The air will start swirling inside the lens and this is what you wind up with as an end effect.
Its *really* noticeable if you take your camera from air conditioning to a hot, dry environment. (If its hot and moist, you just wind up fogging your lens).
