I have only had my Sigma 17-70/2.8-4 (C) for a little over a week, but have not done a comprehensive test. Photozone.de has tested the lens on the Nikon D7000 (16 Mpx APS-C) and his results show that while decent corner resolution wide open at 17mm that improved to f/8. I have this image posted to Flickr taken at f/5.6 and 17mm and will go upstairs and do a full resolution crop of the border and extreme corner to add a bit later.
(Taken with the K10D)
The point of focus was on the furthest right near bloom.
Here is a full resolution crop at the point of focus. I think this would qualify as "edge".
Note that PP included correction for lateral CA. Without that action the image would have been significantly softer. Even though this is a full-resolution JPEG, the conversion from RAW did cause some image degradation. A TIFF version of the same image can be downloaded from
HERE.
One other caution that I might add is that since this is an internal focus lens,
performance at close focus may be very different than at longer distances. The photo above was definitely close focus.
