View Poll Results: I'd go for...
Pentax DA 50mm/f1.8 3131.31%
Pentax DA 35mm/f2.4 AL 6868.69%
Voters: 99. You may not vote on this poll
05-01-2014, 01:23 PM - 1 Like   #31
clackers's Avatar
QuoteOriginally posted by pjm1 Quote
But that doesn't stop the lens working at 1.8 - it's just soft outside the centre.
Unfortunately, even the centre isn't sharp until 2.8, with a maximum at 5.6.
I use it for autofocus snapshots, but a cheap manual 1.4 is better when you've got time to set something up.
05-01-2014, 01:58 PM   #32
Rayn's Avatar
Thank you all for your suggestions and advice For the last 2 days I've been reading reviews,comparing shots with both lenses... I've even compared the DOF at minimum apertures using DOF calculator. TBH I was looking for a reason to get the 50mm, but after these last 2 days of research, I've decided to go for the 35mm. The only reason I even considered the 50mm was the f1.8, which I thought would work better for low light photography; Something I have yet to try out. That, and the slightly better reviews of the 50mm. However, after a few of you pointed out that the 50mm is sharp at f2.8 and above (and sharpness is the main reason I'm getting a prime in the 1st place), I've decided to go for the 35mm, which really is more practical for everyday shooting.
I'm gonna pick it up next week.
Thanks again for all the help
05-01-2014, 02:01 PM   #33
clackers's Avatar
QuoteOriginally posted by Rayn Quote
Pick up the 50 at a later date. I have both in my walkaround bag.
They're tiny, cheap and very good - great intros to the world of primes, a Pentax strength.
05-01-2014, 02:07 PM - 2 Likes   #34
Pablom's Avatar
Get them both, they are a steal for what they deliver and you will have a lot of fun with them.
---------- Post added 2nd May 2014 at 00:14 ----------
Don't be fooled, the DA50 is sharp enough at f/1.8, for me at least, and better at f/2.8. I think you made the right choice but if you think the DA50 isn't sharp at f/2 because it is sharper at f/2.8 then I have to disagree.
Both lenses are excellent but not comparable, I believe you should make your choice based on your needs (i.e. focal lenght). but that's just me, my opinion isn't worth more than any other.
05-01-2014, 06:13 PM   #35
QuoteOriginally posted by Pablom Quote
+1
It is sharp at f1.8, but the autofocus let's it down. I manually focus the lens when shooting at apertures bigger than f2.8.
05-01-2014, 06:58 PM   #36
clackers's Avatar
QuoteOriginally posted by robthebloke Quote
Nup. See Imatest results attached, Rob.
But I'll always carry one and use it, though! :-)
Being a bit soft makes it not bad as a portrait lens, especially indoors where something like a Tammy 90 might be a little too long, little slow, and little too revealing of every blemish on the target, I mean, subject's face.
05-01-2014, 07:38 PM   #37
Let's dispute over what "sharp" means to different people.
05-01-2014, 07:52 PM   #38
jimr-pdx's Avatar
I believe the 50 is the better lens, or my copy was at least - but as a first prime, 35mm is more versatile, or it is for how I shoot. Well, enough about me.. neither is a bad lens so you cannot lose!
05-01-2014, 08:12 PM   #39
clackers's Avatar
QuoteOriginally posted by filoxophy Quote
Well, that's why numerical tests exist, Filoxophy.
But they only cut down on arguments, not eliminate them, because you can still argue about methodology, and you need to make sure the cameras underneath are the same if comparisons are required.
05-02-2014, 12:10 AM   #40
pjm1's Avatar
Well done on deciding!
And to set your mind at rest - and confirm that clackers is absolutely right with his point re: sharpness - here are a couple of images just snapped using the 50mm:
Full image (out of camera) scaled to 800px: http://i91.photobucket.com/albums/k283/pjm35/20140502-IMGP8938-fl50mm-ISO400...ps20e790de.jpg
100% crop of centre, showing fuzziness on "in focus" area and some pretty bad CA: http://i91.photobucket.com/albums/k283/pjm35/20140502-IMGP8938-fl50mm-ISO400...ps28ad6bee.jpg
Given what you wanted, the 35mm does seem a better fit, but you'll obviously still be getting a nifty 50 at some point
05-02-2014, 12:14 AM   #41
Pablom's Avatar
You didn't prove anything with your chart, I will even say that if anything you validated my argument.
You are welcome to come up with a new, more convincing one, while I'm outside taking real pictures.
05-02-2014, 12:26 AM - 2 Likes   #42
clackers's Avatar
Pablom, you're free to ignore Pjm1's 'real picture', my experiences with the lens (which is one I like, BTW), and independent third-party testing.
You've clearly made your mind up on the matter, but in contrast, the OP was genuinely open to information to help him make a choice.
05-04-2014, 09:00 AM   #43
ive decided to go with 40mm xs, but like 35mm al2.4 DO NOT TRY SHOOT face closeups. No compression means ugly face
05-04-2014, 10:21 AM   #44
QuoteOriginally posted by killym Quote
The 35/2.4 hardly distorts at all. And the little that exists is very easy to correct.
05-04-2014, 01:51 PM   #45
clackers's Avatar
No distortion either, though (just 0.2% for the XS, according to Photozone).
They both have a 'normal' FoV, wide enough that they're perfect for environmental portraits, shots of family or friends together, and oriented sideways, half-body length individual portraits.
But the 50 is a natural for your 'head and shoulders' from short range. :-)
2014, 35mm, 35mm/f2.4, 50mm, 50mm/f1.8, aps-c, camera, choice, da, da50, days, dof, f/2.8, image, kit, lens, pentax, pentax help, photography, prime, quality, reason, recommendation, sensor
For Sale - Sold: Pentax K-3 + DA 35mm F2.8 Ltd. + DA 18-135mm + DA 50mm F1.8 vrubel Sold Items 7 04-11-2014 05:36 AM
DA 35mm f2.4 AL vs M 50mm f1.7 Northern Soul Pentax SLR Lens Discussion 23 05-25-2013 11:24 AM
For Sale - Sold: Pentax DA 16-50mm F2.8+ DA 50-135mm F2.8+DA 55mm F1.4 +AF540 flash ljay1129 Sold Items 4 11-25-2012 12:34 AM
For Sale - Sold: DA 70mm f2.4 Limited / FA 35mm f2.0 AL / DA 14mm f2.8 ED trustkor Sold Items 5 06-25-2012 10:14 AM
Pentax 35mm F2.4 AL DA L Lens vs Sigma 28mm f1.8 Aspherical orchid Pentax SLR Lens Discussion 8 04-22-2011 12:44 AM
All times are GMT -7. The time now is 05:39 PM. | See also: NikonForums.com, part of our network of photo forums!
