Originally posted by johnyates So, you should now be able to copy the firmware, yes?
No not yet still. I have tried both the sd cards I have and they both come up with read only. I borrowed my wives sd card, we use SanDisk, and that shows read and write. So I will clean/format her card and then see what happens using that card.
---------- Post added 04-28-14 at 06:29 PM ----------
OK then. When the sd card is formatted in the camera the read and write changes to read only. Remember this SanDisk card was from my wives Panasonic and it said read and write under file info until I formatted it in my camera. Both the Pentax and Ricoh Gr removes the write portion!
