04-28-2014, 11:17 AM   #1
Camera Firmware update help with Mac
Still having trouble both with Pentax K5 ll and my Ricoh GR. The downloaded updates will not transfer/enter the formatted sd card.
Never had this problem before when updating my original K5 until I updated my Mac to 10.6.8
04-28-2014, 11:22 AM   #2
jatrax's Avatar
Is the card formatted on camera or computer? Should be a simple file transfer so if the computer can transfer image files back and forth then there should be no problem moving the .bin files for the update.
I would make sure you can transfer other files first, the problem may be unrelated to the firmware update.
04-28-2014, 11:28 AM   #3
the card was formatted in the camera
04-28-2014, 11:32 AM   #4
jatrax's Avatar
So can you transfer files to the card from the computer?
04-28-2014, 11:39 AM   #5
No. Other files will not slide on the card either and the card is not locked. So any idea where the trouble could be?
04-28-2014, 11:41 AM   #6
Miguel's Avatar
Do you have another SD card you can try?
M
04-28-2014, 11:46 AM   #7
Tried a different card with no results either.
04-28-2014, 11:52 AM   #8
jamarley's Avatar
Might be a "permissions" problem. Follow the instruction here - http://guides.macrumors.com/Repairing_Permissions
04-28-2014, 11:57 AM   #9
I though of that but could not find in the 'Mac preferences' so I will try the link you sent and report back latter on.
04-28-2014, 12:16 PM   #10
jatrax's Avatar
I would try formatting the card on the computer and then testing. It could be a bad card. Or it could be a Mac thing....
04-28-2014, 12:17 PM   #11
johnyates's Avatar
Select the SD card icon and right click => get info. In the Get Info window see if you have write permissions. If not, click the lock item, authenticate and adjust.
04-28-2014, 12:47 PM   #12
It says " you can only read ".
I think it should say " you can read and write "
Not sure how to change permission
04-28-2014, 12:49 PM   #13
johnyates's Avatar
QuoteOriginally posted by billy moon Quote
It says " you can only read ". Is that OK ?
No, if you want to write to the card from your computer, you need 'write' permissions. Click the lock button, give your password when asked, and then change it.
---------- Post added 28th Apr 2014 at 01:52 PM ----------
Actually, there should be a little check box on the bottom of the get info window that says "ignore permissions on this volume". It should be checked. That is probably the more 'correct' solution.
04-28-2014, 12:59 PM   #14
I think we are using different computers. I'm using a Mac
04-28-2014, 01:02 PM   #15
johnyates's Avatar
I too am using a Mac.
If you have 'read only' permissions on your card, you'll not be able to write to it. I've given you information how to fix it.
camera, camera firmware, card, copy, firmware, firmware update, k5, mac, pentax help, permissions, read, sandisk, sd, wives, write
Firmware update HELP billy moon Troubleshooting and Beginner Help 12 03-10-2014 08:42 PM
firmware update...Need Help fnflying Troubleshooting and Beginner Help 9 03-31-2013 10:24 AM
Ater firmware update does your camera change folder numbers? barondla Pentax Q 2 11-03-2012 07:44 AM
Mac Users Warning on Firmware Update 1.02 joelovotti Pentax K-5 18 01-19-2011 08:39 AM
Help with k-x firmware update kiwislice Pentax DSLR Discussion 7 02-25-2010 12:57 PM
All times are GMT -7. The time now is 02:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
