Originally posted by PPPPPP42 I never shoot without a lens hood, sometimes its more useful than others.
Without knowing your experience level here is my 2 bits worth of advice, but I definitely don't know what I am doing.
Change the time of day in that picture, even if you eliminated the flare you should have the sun about 45 degrees farther around to your left to light up all the objects in the foreground better. As it stands you have mostly sun glare off all the highly reflective wet areas and dark shadows so all the color got bleached out.
Portrait orientation landscape photos can work but you have to have depth of field and exposure set to get a lot of foreground detail without making the distant stuff out of focus. Usually that orientation is to highlight the details leading up to the horizon, or to emphasize a big sky.
Look up the definition of hyperfocal, and use a tripod with the 2 second timer to both adjust the height to change what foreground distance is in the frame and to get longer exposures at smaller apertures to increase depth of field.
Early morning or later evening from the correct direction with a long exposure works nice on a beach as the wet areas pick up the colored glow of the horizon more than your eyes.
It seems all the exif data was stripped from your picture which makes it harder to judge what was done.
I would suggest investing in a DA15 if you like landscape, I think it would suit you plus being a prime it has the depth of field scale that is so helpful for those portrait orientations.
Brilliant - thanks for these comments! I read about hyperfocal distance a while back and then promptly forgot all about it. I now have installed a DOF/HF calculator on my smart phone. I need to remember to take a tape measure with me to make sure I leave enough space between the camera and the first rock...
My experience level is... erm... 6000 photos!
Seriously, I'm just starting out and with so many different things I want to take photos of (kids, other family, landscapes, mountains, sunsets/rises etc.) I feel I've barely scratched the surface of any of it. Apologies for the lack of EXIF data - I think that must be a photobucket problem? I had -1.5EV dialled in, zoom set to 18mm, ISO140 (I was on TAv unusally) exposure 1/1000 at f/8. Next time I'd push to f/11 to get more DOF - I think I used f8 as it's pretty much bang in the sweet spot of that lens (which is ok for a kit lens, bar the flare issue). I'd love a 15mm LTD but my LBA needs curtailing for a wee while... having bought all five of my lenses in the last 3 months (including my favourite DA*) I will be in the bad books if I get any more right now!
The great thing about this location is it's five minutes from my house, so I can go back and revisit the photo over and over. I also have Loch Lomond about 20 minutes away so I'm planning a sunrise trip there one morning... hopefully get a shot of the sun coming up over Ben Lomond with the Loch in the foreground. I'll need to take the mandatory withered, bleached branch with me, of course
Nass... thanks for the encouragement and btw I love your extreme macro site (that is yours isn't it??) - I'd love to get into that at some point.
