Hi all I just received my K3 and here are a few things I'm finding out. I was having trouble opening a raw file or dng file . I have window vista 64bit and the new cd program that comes with the camera won't open in vista 64 bit. even tho it has a 64 option Also the adobe dng converter 8.3 won't show the raw files from the camera ,and you have to have windows 7 before you can open adobe 8.4 . I did find out that with Vista if you have lightroom 2 it will open the raw files and I found this video on how to save the raw file after you do your adjusting to jpegs . this video is for lightroom 4 but it might be the same in lightroom 2 . I'm going to give it a try today .
I also found out that from the good people here that you need photo shop cs6 before you can open the raw files in it. because it will let you load the adobe 8.4 in to it . I have cs2 and it won't open in it . So I guess the best thing to do is upgrade to windows 7 or higher to be able to use the cd that comes with the camera or have windows vista 32 bit . That's all I know right now but if I found out anything else I'll let you know or maybe people that know what there doing will post something on this thread . Can anyone help me figure out why the new cd won't open in vista 64 bit I also found this video and its in lightroom 3
I just saved the dng from the k3 using lightroom2 and changed it into a jpegs and it worked great . And it was pretty easy after I watched the videos . Now I can use jpegs in cs2 .
