Originally posted by photolady95 UBCD And if you're not sure how to burn an .iso image, use this guide
Note that once burned to CD, you will use the UBCD to boot the computer. There are a ton of tools and figuring out which one to use is a challenge. At the very least, you will want to find and run the diagnostic programs for your drive and probably also retrieve the S.M.A.R.T. logs from the drive. The S.M.A.R.T. long test is also a good thing to do. Those will allow you to rule out a physical problem with the drive.
The Parted Magic program (also on UBCD) provides a very nice desktop environment for its suite of tools. Highly recommended.
BTW...use the download link on the far left of the UBCD Home page and scroll down to the bottom of the download page to find the actual links to get the .iso file from one of several mirror sites. Ignore the other links and flashing lights and such.
