Originally posted by rossph Hello,
I purchased a sigma APO TELE converter 1.4x EX DG the problem is I have a K5 with a 18-55 pentax DA lense and a 55-300 Pentax DAL lense. the teleconverter fits on the camera body but it is to large to fit the lense itself.
Any Idea's I did lots of research and it seemed like it should work?
I am a newbie to this and thank you for your help.
Thanks
You've recieved correct advice that the Sigma is a 'matched' converter for only a select number of lens.
A word of warning you may be able to shoe horn a different lens on but if the rear element move during focusing or zooming you may well smash the lens rear element in to the converters forward element destroying both.
One othe point putting a conveter on a cheap lens is a complete waste of time and money , Though your Sigma is a good converter and will produce decent results with high quality matched glass (SIgma 70-200 f2.8 etc) it will just magnify the aberations of a cheap lens resulting in a worse image than cropping alone would achieve.
