05-27-2014, 06:57 AM   #1
Aperture changes during exposure bracketing
Hi all,
I have recently found out that my K-30 changes both exposure time AND aperture when making bracketed shots. Is there any way to keep the aperture constant and change only the exposure time (other than to use M mode and change the time manually for each shot)?
Thanks,
Viktor
05-27-2014, 07:34 AM   #2
boriscleto's Avatar
Use Aperture Priority mode (Av).
05-27-2014, 07:47 AM   #3
I use M mode to set the fixed exposure for panoramas. In Av mode the camera would measure light differently for every bracketed 3-tuple and I would get differently exposed shots in my panorama.
05-27-2014, 08:15 AM   #4
boriscleto's Avatar
Hugin — Stitching auto-exposed panoramas
05-27-2014, 08:46 AM   #5
QuoteOriginally posted by viktorpus Quote
Welcome to the Pentax Forums!
In regards to the quoted text above, would this not be the case for any auto-metered mode? Your only options for keeping the aperture constant are M-mode, Av-mode, and TAv mode. It sounds like your use case is fairly specific. If you need identical exposures (same aperture, shutter, and ISO) for multiple bracket sets, you are limited to manually doing it in M mode.
User-defined bracketing is a cool idea, though.
05-27-2014, 02:53 PM - 1 Like   #6
In my K20D and K-3 it's possible to get bracketing with constant aperture in M mode by setting the green button function in M mode to "Tv shift". It's undocumented but it works. Check if the K-30 has a similar customization setting.
05-27-2014, 05:50 PM   #7
QuoteOriginally posted by markkuk Quote
I just tried it on my K-3 and was astounded! What a cool feature! I do believe that it can be used for the OP's use case if supported on the K-30. Good work!
aperture, aperture changes, camera, change, changes, changes during exposure, exposure, pentax help, photography, time
Changes aperture when manually focusing? kadajawi Pentax K-5 10 06-27-2014 10:58 AM
K-500 (a.k.a. K-50, K-30) remote trigger during exposure bracketing? Rayn Troubleshooting and Beginner Help 2 03-15-2014 03:34 PM
Shutter speed changes even with AE-L during continuous shooting. geomez Pentax K-01 2 05-31-2013 01:19 PM
why the aperture changes for each shot when I use exposure bracketing liukaitc Pentax K-5 5 11-29-2011 02:34 PM
Something to keep dust out during lens changes ectosaur Photographic Technique 21 10-02-2010 09:53 PM
All times are GMT -7. The time now is 03:02 PM. | See also: NikonForums.com, part of our network of photo forums!
