Originally posted by Lowell Goudge i have exclusively used rechargeable batteries with my istD. i tried in a pinch, once to use alkaline, and got about 10 shots. waste of time
as for the delays,. i agree with Jim, you must have hit the AF mode switch.
Yeah alkalines will get you nowhere - you need to use lithium (either rechargeable or non-rechargeables) - a set of Eneloops are relatively cheap and will work great. As to the delay in focus, I'm guessing Jim is on the right track there - I believe there is also a menu option to allow triggering with/without focus - could be when the camera ran out of juice it reset itself to defaults, so you might want to check there as well.
