06-01-2014, 04:57 PM   #1
Lense Issue
I have a Sigma 300mm F/2.8 APO and when connected to my K-3 the camera flashes f--. It will not do anything. All other lenses work fine. Is the Sigma broken?
06-01-2014, 05:14 PM   #2
OregonJim's Avatar
QuoteOriginally posted by jwjohnson9 Quote
No, it's not broken.
It just means that you have the aperture ring set to something other than "A", and that you have not set the "Using Aperture Ring" custom function in the K-3 to "2".
Just set the aperture ring to "A" and it should work fine.
06-01-2014, 06:17 PM   #3
I have the aperture ring set to "A". and the Using Aperture Ring" function set to "1". I failed to mention the lens has a slight bit of play when mounted. The focus method changes to "M" from "AF.S" on occasions.
06-01-2014, 06:49 PM   #4
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
You need to set Using aperture ring setting to number 2, permitted.
pentax help, sigma
lense hood help (50-200mm lense for k-30) obsidianjeff Troubleshooting and Beginner Help 5 05-06-2014 06:46 PM
Universal lense wide lense: Tamron 17-50mm F/2.8, DA 16-45mm F4, DA 17-70mm ? Vejas Pentax SLR Lens Discussion 12 02-11-2014 12:04 PM
K-5 MF lense issue Bcrary3 Pentax K-5 5 02-07-2014 07:01 AM
K-3 old lenses issue and daddy style solution FilipWessman Troubleshooting and Beginner Help 11 01-16-2014 06:42 AM
Noob Question Difference Between a Lense That Does Macro & A True Macro Lense Christopher M.W.T Troubleshooting and Beginner Help 16 07-19-2009 12:20 AM
All times are GMT -7. The time now is 12:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
