Originally posted by OregonJim You can eliminate the card as the problem by powering on without a card (with the door closed, as Steve said).
Yes, I've tried that.
---------- Post added 06-05-14 at 11:06 AM ----------
Originally posted by Adam Sorry to hear that you've been having so many issues! Just one last thing to check- when you replaced the battery after charging it, was it facing the right way? Also, have you tried AA's?
Could also be the power switch, perhaps.
1. The battery would not go in if I tried puting it the opposite direction
2. I have the k-30 which does not come with the AA cartridge to put batteries in.
- Therefore, I shouldn't need to buy another product that didn't come with it just to see if it works.
Originally posted by Steve.Ledger This happens for one of two reasons:
[1] Card door is not closed properly
[2] Card is dead/faulty
Camera won't turn on until a good card is detected and/or door is properly closed.
Like what Jim said, I tried turning it on without the SD. Still nothing.
