06-07-2014, 10:53 AM   #1
schnitzer79's Avatar
Adjusting K-50 AF module
Up until recently I really thought that most of my lenses werent in need of calibration. I had done some quick tests and they seemed ok but only recently I had actually taken the time to set up some focus charts and test them properly.
All of my lenses seem to be set on +8 or +9 in order to AF to be accurate and get really sharp photos. It seems that the in camera AF module is a bit off. it seems that the tolerance range needs to be shifted in the negative direction. At some point, i might actually attempt to adjust the AF module in the camera, just not too sure how to go about it. has anyone attempted this?
I found an article on the k10D on how to do it, but im not sure if it works the same way on newer models.
RiceHigh's Pentax Blog: Hardware Adjust a Pentax DSLR for the AF
is it the same for the k-30/k-50 ??
06-07-2014, 11:09 AM   #2
Page 112 of your user manual has instructions on applying per lens calibration (Apply One) or universal calibration (Apply All). This is C/21 in the setup menu. There was some discussion on another thread regarding whether a change applied to all would require a re-do of existing per lens calibrations. Have fun!
06-07-2014, 11:14 AM   #3
ive already done that for each lens one by one.what im asking is if i can adjust the cameras hardware
06-07-2014, 11:20 AM   #4
OregonJim's Avatar
QuoteOriginally posted by schnitzer79 Quote
I'm sure there is a similar adjustment in the K-50, but you're on your own to find it. I would be concerned with compromising the weather sealing.
06-07-2014, 11:57 AM   #5
Good point oregonjim. Hadnt thought about that
06-07-2014, 08:23 PM   #6
If you do the "Apply All" you are doing the what can be accomplished through the firmware. I would suggest that as the first step. If you want to have the AF module realigned, that can be done too, but $$$. As OregonJim suggests, doing it yourself is probably not a good idea, particularly since the adjustment would be a few tenths of a millimeter at most and there is a significant risk of the module not being true after the adjustment and it is unlikely that you will find the hardware similar to what is pictured in RiceHigh's three year-old post and it will void what is left of your warranty.
06-08-2014, 12:22 AM   #7
you're probably right. ill just live with it since +8 for most lenses is fine, apart from my sigma which needs +4. its just bugging me a little knowing that the AF module is off. it seems that the camera's and lenses' tolerances are both on the + side. i would send it off since its still under warranty but last time i sent my camera out for an aperture arm replacement, it took 2 months. plus it might come back worse than it was before.
ive only tried the focus tests at maximum aperture and these were at 50 x focal length. dont know what results i will get for distant objects and narrower aperture. the quick tests i did a couple of months ago showed that the lenses were ok.of course, those were rushed and hand held. is it possible that the firmware update to v1.02 might have changed anything in respect to the focusing?
06-08-2014, 08:10 AM   #8
It would bother me as well. I would hope that factory calibration would not result in that large a bias.
af, camera, lenses, module, pentax, pentax help
For Sale - Sold: Pentax K-m + 50-135 + F 100 macro + sigma 17-70 + 50-150 + tamron 17-50 + metz 50 AF blem49 Sold Items 11 07-26-2013 03:25 PM
For Sale - Sold: Ricoh GXR body A12 M module A12 28mm/2.5 Lens Module ddhytz Sold Items 4 06-01-2013 05:53 AM
K-5 II and K-30 do not Share the Same AF Module Class A Pentax DSLR Discussion 8 09-19-2012 11:02 PM
AF Adjusting a zoom opiedog Pentax DSLR Discussion 10 05-08-2010 05:21 PM
All times are GMT -7. The time now is 06:11 AM. | See also: NikonForums.com, part of our network of photo forums!
