Originally posted by ERICDE705 So would it even be worth it to upgrade the firmware? I'm afraid it would amplify the problems instead of solving them. Any thoughts?
New firmware is not going to amplify anything. It will either improve the situation or change nothing. Since the only hope of firmware helping was if you were using newer cards and you stated that was not true so then I don't see a firmware update making any difference.
Normally I say go ahead and update the firmware anyway because often new firmware fixes little things we never knew were wrong.
BUT in this case I would not recommend it. Loading new firmware is a delicate operation and can 'brick' your camera if it fails. And loading it from a possibly faulty memory card (or memory card interface) does not sound like something I would be comfortable with.
