06-16-2014, 05:53 PM   #1
Autofocus problem K30 18-55DAL kit lens
Hello all, I am a beginner photographer with a K30, my first DSLR. I have been shooting for about a year, mostly my kids. I recently took the camera on a long plane trip (18 hours, during which the camera was packed in its padded case inside the padded section of my backpack).
On the first time the camera was removed from the case after the trip, the autofocus did not work.
When I press down on the button, I hear the whirring sound that should accompany a change in focus, but the focus never changes. The whirring sound just keeps going as long as I have the button depressed.
I have tried several different subjects, with the same results. I tried changing from AF-S mode to C, with the same results. When I changed lenses, however, the autofocus worked. This leads me to believe that something is wrong with my 18-55 lens.
How do I figure out what is wrong? What should I do? Thanks in advance to all the experts out there.
06-16-2014, 06:22 PM   #2
Try to wiggle the lens slightly after mounting it, as the AF shaft may not have fully engaged. Also, if you set your camera to manual focus, then mount the lens, then set it to AF, this would have the same effect. Hope this helps!
06-17-2014, 02:33 AM   #3
Unfortunately, neither of these suggestions had any effect. Where is the AF shaft located? Maybe I can take a closer look at it and see if it is somehow broken...?
06-17-2014, 02:37 AM   #4
altopiet's Avatar
The one on the right...if you take a small screw driver, you should be able to turn it...
autofocus, autofocus problem k30, button, camera, focus, k30, lens, pentax help, results, trip
Autofocus problem with Tamron 18-200 davea66 Pentax K-r 7 03-23-2014 04:37 AM
For Sale - Sold: Pentax K30 + 18-55WR Kit jusjee Sold Items 2 10-22-2013 09:36 PM
K30 18-55 or 18-135 kit lens?? PaulJRJ Visitors' Center 24 04-29-2013 07:18 AM
odd front focus problem with kit lens and Tamron 18 - 250mm lens jlaubza Pentax DSLR Discussion 12 10-30-2011 09:42 AM
For Sale - Sold: quantaray 2X Autofocus teleconverter; Pentax 18-55mm kit lens idler Sold Items 9 07-02-2009 12:06 PM
All times are GMT -7. The time now is 02:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
