06-20-2014, 09:05 AM   #1
Difference between Pentax flash and third party
Are there any advantages to the Pentax flash compared to third party flashes?
06-20-2014, 10:14 AM   #2
panoguy's Avatar
The newest Pentax flashes are weather-sealed (AF-360FGZ II, and 540FGZ II) and have lots of direct, physical controls (buttons and dials). The older models (without the "II") have the same controls and are on sale right now.
Third party flashes (Metz, Sigma, etc.) that are "P-TTL compatible" are generally going to provide the same light and performance, without the weather sealing, and (in the case of Metz) with fewer physical controls and harder to navigate interfaces.
Assuming you want to use P-TTL for automatic exposure, and have access to special flash features like High Speed Sync and such, your source for information on Pentax-compatible flashes is here, thanks to our own MattDM:
The Definitive Guide - Pentax P-TTL Flash Comparison
If you just want a basic flashgun with an on/off switch and a slider to adjust power, then there are lots of very cheap, all manual (camera can't control them) flashes out there. In general, only go this route if your budget is severely limited or you really know what you're doing with flash. P-TTL is quite helpful, and the higher-end flashes can grow with you as you get better and start experimenting.
06-20-2014, 10:43 AM   #3
Just1MoreDave's Avatar
The third-party flashes may need a firmware update at some point to stay compatible.
06-20-2014, 11:10 AM   #4
JimmyDranox's Avatar
The new pentax flashes also have a light for video.
camera, difference between pentax, flash, flash and third, party, pentax, pentax flash, pentax help, photography, third
Really confused on Third Party Flash for Pentax K30 rp_dxn Flashes, Lighting, and Studio 12 09-21-2013 08:54 PM
Can somebody explain me difference between Slave and Servo modes on Metz flash i83N Flashes, Lighting, and Studio 4 06-21-2013 01:24 AM
third party flash for k5 Lakai Welcomes and Introductions 2 05-17-2013 08:16 PM
Older third party flashes and Pentax P3 compatibility CanadianPhotoLuddite Pentax Film SLR Discussion 6 04-23-2013 01:56 PM
difference between flash compentsation and regular EV compensation? tram57 Pentax DSLR Discussion 8 03-05-2010 08:26 PM
All times are GMT -7. The time now is 09:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
