Originally posted by jatrax Firmware updates can help older cameras with compatibility with newer cards but in your case I doubt that is the problem since they did work for a while. Have you tried formatting the cards in the camera not the computer? That is the recommended procedure.
I format all cards in the camera as soon as they are inserted, each time. I also don't buy anything but Sandisk Extreme and Extreme Pro cards, they cost a little more it's worth the peace of mind to me.
Trying to format in-camera returns the same "memory card error" message, unfortunately. Actually, I just remembered that something like this happened years ago (with my old Minolta Z5) and I was able to get a few cards working again by formatting in my camcorder. I might give that a try tonight.
---------- Post added 06-24-2014 at 03:22 PM ----------
Originally posted by Na Horuk I read quite a few complaints about Sony cards, but I am surprised it would happen suddenly. Were the cards exposed to magnets?
Oh and btw, Sandisk seems to be the most trusted card brand here.
Maybe that's why OWC was selling them so cheap ($13.99 each, I think)? No magnets were involved, and as far as I know, flash-based storage isn't susceptible to magnets as mechanical hard drives are. I could be wrong, though.
---------- Post added 06-24-2014 at 03:26 PM ----------
Originally posted by stevebrot The failure of these cards may be due to having the wrong filesystem applied at some point. Even with an update to the camera firmware, an in-camera (shallow) format will leave the bad filesystem intact and the cards will still fail. Reformat the 32 GB cards using the utility from the SD Association to do a full format with erase. That will create a SDXC compliant card formatted with the exFAT filesystem.
https://www.sdcard.org/downloads/formatter_4/
In-camera format should be adequate thereafter, assuming that the firmware supports SDXC.
That's what I used - the Mac version. The two options it gives are "Quick Format" and "Overwrite Format"; tried both with no improvement. There's also an "Option" button that enables "Logical Address Adjustment" with a note that "This option is for interoperability with specific devices." I did not try that option, but may as well at this point. I don't think it's going to do any more harm.
