06-24-2014, 01:41 PM   #1
Focus problem with the K-3
Hi guys (and girls),
I love my K-3 and have taken lots of pixs with it. I also use a K-5 which I love.
Here is the issue: the K-3 seems to freeze the focus and it will not re-focus on any other spot. This happens
sporadically and all I can do is turn it off and on. I had the problem with the Pentax 18-135 and the Sigma 18-250.
I had the update in software about 3 months ago. Maybe there is another update?
Any ideas will be appreciated as it is an annoying problem.
Thanks in advance!!!
06-24-2014, 02:26 PM   #2
If you want the camera to re-focus without letting go of the AF button/half-press, you need to be in AF-C mode. Is that what you're using? The K-3 has a lot more AF modes as well as a new interface, so it can be a bit confusing at first.
06-24-2014, 06:28 PM   #3
QuoteOriginally posted by lezama Quote
It sounds like you are saying that the AF feature sometimes locks up and that you must power down before it will work again. Is the AF the only thing locked or is the whole camera non-functional when this happens.
06-25-2014, 04:11 AM   #4
Hi Adam,
I do appreciate your response. But, no, I am using the K_3 in AF-S mode only and it focuses fine at first but when I change focus points anhd hit the shutter release to half way it will still be focused in the old spot and not allow a change. The only thing that unfreezes it is a re-boot.
Thanks, and help!!!
Ricardo (lezama)
---------- Post added 06-25-14 at 07:14 AM ----------
Hi Steve,
Thanks for the response. The only thing that freezes is the Auto focus, which I always use in AF_S. As far as I know I have the latest firmware but I will check
Thanks, and help!
Ricardo (lezama)
06-25-2014, 08:22 AM   #5
Ricoh/Pentax support may be your best option if the behavior is as you describe.
06-25-2014, 01:57 PM   #6
Hi Adam, I do appreciate your response. But, no, I am using the K_3 in AF-S mode only and it focuses fine at first but when I change focus points anhd hit the shutter release to half way it will still be focused in the old spot and not allow a change. The only thing that unfreezes it is a re-boot. Thanks, and help!!! Ricardo (lezama)
Are you using AE-L/AF-L?
12-12-2014, 08:34 AM   #7
This is a belated follow up on the issue. I discovered why the Autofocus froze sporadically. I have the battery pack on the camera and when holding it sometimes my hand touches the shutter button in the battery pack freezing the focus point. So issue is solved. Thanks everyone...!!!
12-12-2014, 11:59 PM   #8
Glad you found the source of the problem.
af, change, focus, k-3, love, mode, pentax help, response, steve, thanks, update
K-3 auto focus problem DAKS Pentax K-3 23 11-11-2014 03:03 AM
Greetings (with a brand new K-3 Problem) Convert Welcomes and Introductions 5 05-19-2014 10:25 AM
Pentax K-50 with uncorrectable (?) front focus problem and horrendous Ricoh service anirbax Pentax DSLR Discussion 7 03-29-2014 08:34 AM
Tamron 70-200 auto focus faster with k-3 or k-5 IIs ? skid2964 Pentax DSLR Discussion 11 01-25-2014 12:27 AM
K-01 Problem with Focus jdarrough Troubleshooting and Beginner Help 21 07-01-2013 10:04 AM
All times are GMT -7. The time now is 11:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
