06-26-2014, 03:04 PM   #1
Weird happenings when I review pics with my K-5IIs
When I view a picture I just shot, parts of the sky will blink red off and on. I have never seen it do this before, anyone know why it might be doing this? The camera is the Pentax K-5IIs.
06-26-2014, 03:10 PM   #2
aurele's Avatar
it just mean that the part is burn is the case of the sky. The sky appear so bright that not enought detail is recorded.
06-26-2014, 03:15 PM   #3
QuoteOriginally posted by aurele Quote
Ah I see, I have never had it do that before, I wonder if I have accidentally set something I shouldn't have, I'll have to look at that.
Thanks for your reply
06-26-2014, 03:21 PM   #4
Imageman's Avatar
My explanation is,
Many cameras have a warning when parts of the image are beginning to overexpose. Its usually red blinking highlights to show you the affected parts.
All it means is the exposure is a little too high and its there so you can be warned and adjust the camera and take another image slightly darker.
The technique recommended is to review the image as you do, then if you see blinking red, look at the histogram, this will show the graph hitting the right hand edge (overexposure).
Then use the exposure compensation to lower the exposure 1 or 2 stops and then take again, or use different metering or manual exposure.
The blinking red areas should now be gone.
It sounds complicated but it isn't. Practice using exposure compensation so when it happens again you will know what to do.
06-26-2014, 03:27 PM   #5
aleonx3's Avatar
on the second tab of the MENU, uncheck the box "Bright/Dark area" then you will not see it when you try to view the picture just taken.
06-26-2014, 10:38 PM   #6
Thanks
k-5iis, pentax help, review pics
With K-5IIs selling so cheap, should I buy a K-3? bonaprof Pentax K-3 36 02-25-2014 02:56 PM
K-5IIs - when to buy? Lukinosity Pentax K-5 30 04-27-2013 05:31 AM
Weird problem with my K-5 treebeard Pentax K-5 13 03-02-2013 08:02 AM
K-5IIs Review in ePhotozine Winder Pentax K-5 3 01-31-2013 01:38 AM
When Will the K-5II & K-5IIs Test Shots Start Coming Out? reivax Pentax DSLR Discussion 7 09-22-2012 07:07 AM
All times are GMT -7. The time now is 01:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
