06-27-2014, 05:26 PM   #1
K100d Firmware v1.02 snd SDHC Card
I just upgraded a newly purchased used k100d to v1.02 of the firmware which is supposed to allow SDHC cards up to 32 GB.
When I inserted an 8gb Lexar Professional SDHC card into the camera, the image counter remains at 999, and never changes.
However, when I insert a 2gb SD card, the counter decreases each time I take a photo.
I thought the new firmware was supposed to allow you to use higher capacity SD cards, especially SDHC.
Any similar experiences or suggestions? Thanks.
06-27-2014, 05:52 PM   #2
You're good to go: since it's a 3 digit display, the counter won't go down until there at fewer than 999 pictures remaining.
06-27-2014, 06:03 PM   #3
Imageman's Avatar
Sounds to me like the update worked fine and your using the card.
It also sounds to me like the 999 is a camera hard limit that the firmware update cannot affect.
See what happens as you take more images, does the counter spring into life after another hundred or so images have been exposed.
card, cards, firmware, firmware v1.02 snd, k100d, k100d firmware v1.02, pentax help, sd, sdhc, v1.02, v1.02 snd sdhc
yaaay, successful update to ist DS firmware 2.02, now I can use my 4Gb SDHC card jamelikat Pentax DSLR Discussion 15 06-21-2017 07:59 PM
pentax releases firmware v1.02 for k-3 koper Pentax News and Rumors 7 03-02-2014 01:25 PM
K-01 Firmware update - V1.02 Docrwm Pentax K-01 42 05-04-2013 06:04 AM
K-5 II & IIs Firmware Updates v1.02 Docrwm Pentax K-5 & K-5 II 28 02-25-2013 04:58 AM
Firmware v1.02 Kunzite Pentax K-5 & K-5 II 94 02-10-2011 01:02 AM
All times are GMT -7. The time now is 01:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
