Originally posted by Adam On film bodies, non-Pentax lenses need to have manual aperture diaphragms and aperture rings in order to meter properly (otherwise, the camera will assume wide-open exposure). Stop-down metering is not a supported feature since film bodies weren't "crippled". Then just shoot away in Tv or M mode
Do you mean they need those pin thingies like on the m42 lenses? Because the Leica R system didn't have autofocus, so all the lenses have manual apertures and aperture rings. On the K5 they work correctly now with aperture priority (and manual, of course). No problems.
The main point is that on the K5 the meter works. On the film bodies the meter won't work, period. It doesn't matter whether I stop down the apertures or not, the LED just blinks the way it does when the camera can't meter.
I have been using the 28mm Elmarit-R on the Pentax MX using Sunny 16 and it exposes according to whatever I set, meaning the lens works on the body and the camera lets in light through the lens. It's just that the built-in meter doesn't function, which is a great incovenience. So it's either Sunny 16 or carrying an external meter (which I don't have).
