06-30-2014, 09:55 AM   #1
Please Note: The camera menu's "Reset" is NOT a factory reset
There seems to be a misconception that the Reset command in the K-5's (and probably other models) Setup menu performs a full factory reset.
That is not the case, though:
A true factory reset would also reset the AF adjustments that can be made thru the DEBUG menu, but it doesn't.
For instance, if you get a used camera and think you'll get it to reset everything - no, it won't.
But then, that's not truly expected from the Reset command, either. You'd not want to reset such adjustments usually, and other data, such as the internal counters for exposures etc. should also not be cleared.
So, yes, the Reset function is just fine as it is. But please do not call it a factory reset, because it isn't. A true factory reset would make the camera appear brand new and have all serviceable adjustments reset.
adjustments, camera, command, factory, menu, pentax help, reset
Factory Reset gjtoth Pentax K-5 7 06-30-2014 01:38 PM
Now this is the A7 "S" camera Sony should have made - the new rumoured Leica S Christine Tham Non-Pentax Cameras: Canon, Nikon, etc. 6 04-10-2014 12:14 PM
Suggestion "buttons" to reset forum skin/appearance RoxnDox Site Suggestions and Help 2 08-18-2011 01:03 PM
Claims that factory reset "cures" FF issues MrPetkus Pentax K-5 22 03-03-2011 02:48 PM
Cameraīs all settings not reset? HeG Troubleshooting and Beginner Help 6 10-27-2009 05:25 PM
All times are GMT -7. The time now is 01:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
