06-30-2014, 08:44 PM   #1
K10 sensor issue
So I was working on some photos this evening and started to see a recurring line. It runs a bit less than halfway through. And it is the sensor. This is with no lens mounted. So is my K10 sensor failing?
This is cropped. Line is in upper part of box.
PENTAX K10D  Photo
06-30-2014, 10:42 PM   #2
schnitzer79's Avatar
i remember reading somewhere on this forum that its happened a few times on the k10d and k20d and it was the sensor...if it is then not worth replacing
07-01-2014, 05:54 PM   #3
There was an early issue with "noise" banding with high ISO with the K10D in low light.* Your image does not look like that. Have you tried reformatting the SD card or using a different card?
* Never saw the issue on my K10D.
07-02-2014, 08:40 AM   #4
FrankC's Avatar
If your camera has pixel mapping feature, then that may fix/mask the problem. If you had a dead pixel, then the line would black AND it would from edge to edge on the sensor and not just part way.
Here's a link that states that you're experiencing stuck pixels. Ask Olympus: What is Pixel Mapping?
07-06-2014, 08:23 PM   #5
Yeah thought it could be stuck pixels. The K10 doesn't have pixel mapping. A little more PS for me I guess until I can spare a few bucks for the K3.
k10, pentax help, sensor
k10 d lens issue. mikros1953 Pentax SLR Lens Discussion 6 09-05-2013 11:58 PM
Lens or sensor issue Ofer Hadas Pentax K-5 3 06-14-2013 12:36 AM
Opinion on sensor issue Ray Cox Pentax K-5 11 04-28-2013 10:54 AM
K10 Issue vampireloon Troubleshooting and Beginner Help 3 10-05-2012 10:49 AM
k10 sensor failure? import silvia Pentax DSLR Discussion 5 07-10-2011 10:56 AM
All times are GMT -7. The time now is 12:21 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
