07-01-2014, 06:20 PM   #1
? Re Metz 58-AF2 not registering lenses ...
I'm using a new to me Metz 58 AF2 on my k20d and had a quick question. When I attach my 50 mm FA 1.4 it shows up as an A70mm when using Pttl. I can change it to M50mm on the flash but should that be necessary?
Thanks,
Ken
FYI my 40mm shows up as a 50mm
My 70mm shows up as an 85mm
07-02-2014, 05:16 AM   #2
kkoether's Avatar
Try toggling Zoom Size on your flash.
Hope that helps.
07-02-2014, 08:32 AM   #3
FrankC's Avatar
You're not taking into account the crop factor of your lens. The lens barrel may be at the 50mm position, but the focal length is equivalent to an 80mm on a 35mm or full-frame camera, which would make the flash's decision to be set at 70mm correct.
07-02-2014, 11:24 PM   #4
QuoteOriginally posted by FrankC Quote
But the distance from camera to object does not change with the crop factor.
07-03-2014, 08:57 AM   #5
QuoteOriginally posted by Schraubstock Quote
This is true, but the flash has an internal zoom feature that varies the illuminated area according to lens FOV. That feature is normalized to the 35mm equivalent.
metz, metz 58 af-2, pentax help, re metz 58-af2
Metz 58 AF2 meetering off on Pentax K5 urssu Flashes, Lighting, and Studio 7 05-01-2014 11:26 AM
Metz Mecablitz 58-af2 - Works With K-30? ahw Pentax Camera and Field Accessories 13 10-08-2012 06:09 AM
Wireless Servo Mode on Metz 58-AF2 teljalis Flashes, Lighting, and Studio 4 09-25-2011 10:35 PM
Metz 58-AF2 krebsy75 Ask B&H Photo! 2 06-28-2011 08:45 AM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
