11-26-2014, 01:29 PM   #16
Buy a Pentax AF200T and use that for the time being. They're brilliant flashguns, trigger voltage is safe for digital, but they sell for pennies.
12-14-2014, 08:50 PM   #17
Pentax K-X flash stuck
I have a similar problem as OP. The flash does not prop open upon depressing the switch. I opened the top cover to check inside. The switch is "clicking" and visually appears to be in good condition, free of any dirt or stickiness. The flash hinge-spring assembly is also in good alignment so that is also not the problem. That leaves the solenoid assembly which would latch and unlatch the hook that holds the flash closed. The hook in normal position is close to the electromagnet and thus would need to be pulled away from that electromagnet to release the flash. Based on this information, what do the experts here think?
I am an engineer and am able and comfortable in handling these devices.
12-14-2014, 09:09 PM   #18
Did you follow the link provided by ruggiex in post No 9?
There is a position switch operated by a cam on one of the flash pivots, the flash won't pop up if the camera already thinks it's up.
12-15-2014, 01:30 PM   #19
And, there is a switch operate by the push pin from seat of external flash to prevent internal flash from popping when an external flash is installed. I think this contact is on the same circuit as the position switch, if I remember them right...
12-15-2014, 02:08 PM   #20
QuoteOriginally posted by twey Quote
So there is, that I didn't know.
No, separate circuit by the looks of it.
External flash switch on the left (silver) flash position (up/down) on the right (gold).
PENTAX K-x  Photo
PENTAX K-x  Photo
flash, kx, pentax, pentax help, pentax kx flash, pop, stuck
Pentax Kx Flash Misfire ras25 Troubleshooting and Beginner Help 2 12-15-2012 04:05 PM
Stuck lens on KX gbh Maintenance and Repair Articles 18 09-15-2012 02:05 PM
KX stuck in autofocus, but switch is stuck in MF icywarm Troubleshooting and Beginner Help 4 08-07-2012 07:21 AM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
All times are GMT -7. The time now is 07:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
