07-03-2014, 06:56 AM   #1
K-01+DA* 50-135 water-damaged: Any chance of recovery?
Well, I borrowed a friend's K-01 for a shoot that required video... and as much as I tried avoiding bad things in the location (countryside shanties propped up in the riverbank), an accident happened. The K-01 + my DA* 50-135, mounted on what I thought was a good-enough tripod, fell down lens-first, the hood cracked and the window popped and disappeared. To make things worse, the entire setup slipped into the water... took me around 5 seconds to get it.
I immediately removed the battery, wiped both camera and lens clean, and checked if any water had seeped into either. The lens was miraculously fine; the K-01 however, looked 50/50 - there was no water in the sans-mirror box, no trace of water entering from that part, but the ports (mic, HDMI, PC) had some. SD card slot was dry, so was the battery cavity with the exception of the battery door which had some drops.
I waited some hours before reluctantly trying it again, and for some reason it turned on, which made me think everything was OK. Tried a manual lens, it was fine. But I tried my DA* on it again and some problems became evident: It had a lot of difficulty operating the AF, and the power fluctuated, from showing green to red and sometimes a shocking "DC in" with only the battery in it. Promptly shut it down and removed everything again. As we were stuck in location I couldn't find a way to dry the camera completely so I waited until nightfall after the shoot. My friend tried it again, it was dead.
So... just asking ... (the camera is now in an airtight box with two dehumidifier packs) is there any chance the camera can still "come back to life?"
...also, the lens' focus ring is making odd, sort of scratchy (like friction-generated) noise when the focus ring is being turned manually... doesn't happen when AF'd from a camera though. Should I also send the lens for repairs? Also, is there anything I shouldn't / should do for the items involved? Thanks in advance...
07-03-2014, 07:29 AM   #2
I suppose the "good" news is that the K-01 isn't worth that much anyway, while the lens is. The hood probably absorbed most of the impact - doing its job. The lens probably should have been rinsed off in the shower - not with high pressure or overly warm water. But this should normally be done while attached to a WR body - which I don't believe the K-01 is. One would expect the lens still has some grit around it from the dirt or unclean water.
07-03-2014, 08:07 AM   #3
jatrax's Avatar
QuoteOriginally posted by Alizarine Quote
Chance, yes. Keep swapping out the dehumidifier packs, they only absorb so much. If you do not have more try rice. The process might take longer than you think, days even weeks.
Also, it's possible the AF on the lens was damaged, or something bent or misaligned that caused the focusing issues. Not news you want to hear but you should test the lens thoroughly before deciding it was all the camera. Could just be grit or something but then the seals might be compromised. Hard to say without the lens in my hand but if you feel something is wrong I would likely send it in for cleaning and get the seals checked. An impact can cause lots of issues that still allow the lens to appear to function, at least for a while.
07-03-2014, 10:21 PM   #4
QuoteOriginally posted by DSims Quote
thanks for the tips! rinsed the DA* lens while mounted on my K-5 IIs. It works fine now, and the scratchy noise is gone. Will still go to a repair center to have it checked tomorrow though, just to be sure.
07-05-2014, 11:33 PM   #5
Glad to hear it! Let us know if it checks out OK!
07-07-2014, 04:27 AM   #6
This just in:
dehumidifier and rice worked like magic! K-01 IS ALIVE!!
07-07-2014, 06:57 AM   #7
Otis Memorial Pentaxian
This just in:
Wow! Incredible!
07-07-2014, 07:49 AM   #8
jatrax's Avatar
Excellent! I am always amazed when I read one of these stories about delicate electronics being dunked and then dried and working fine. Glad it all worked out.
07-07-2014, 05:19 PM   #9
That's great news!
07-08-2014, 07:51 AM   #10
thanks for the tips everyone, I never really thought a drowned K-01 will see the light of day again. Well, time to go shooting!
battery, box, camera, da*, focus, k-01, k-01 da*, lens, pentax help, shoot, water
Tamron 17-50 on K-01 - any BF/FF issues? yellowbrick Pentax SLR Lens Discussion 8 06-09-2014 02:31 PM
Any chance of a longer DA Limited? klh Pentax SLR Lens Discussion 11 01-27-2013 12:59 AM
Any chance of a Xmas special deal? lightbulb Photographic Industry and Professionals 5 12-10-2012 09:43 PM
Any chance of a K-r white kit with the 55-300? Taobat Ask B&H Photo! 7 03-30-2011 05:53 PM
Finally got a chance to use the K20 & DA* 50-135 =) PICTURE heavy! DuckysDoll Post Your Photos! 23 01-21-2009 10:13 PM
All times are GMT -7. The time now is 04:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
