07-05-2014, 09:23 AM   #1
mblanc's Avatar
K-x does not take pictures in Live View
Hello,
For some reason, my K-x does not take pictures in Live View. I can hear the shutter operate, but then when I go to review the image, I do not see anything. Everything works fine when I use the viewfinder (which is >=99% of the time anyway).
Are there any settings that prevent taking pictures in Live View?
Thanks.
07-05-2014, 12:26 PM   #2
QuoteOriginally posted by mblanc Quote
Hello,
Thanks.
Are you sure you are hearing the shutter operate, and not the live view auto focus fine tuning ? To check you should try some shots on manual focus, if it works then you've found your problem. In live view there is often a fraction of a second delay while the camera confirms focus, even if it was spot on, with the sound of the screw drive focus mechanism being engaged, which could be confused with the sound of the shutter (I know, it's happened to me more times than I would like to admit)
Hope this helps.
Chrispy
07-06-2014, 07:05 PM   #3
mblanc's Avatar
Thanks - but I had the camera set to MF.
07-09-2014, 07:06 PM   #4
mblanc's Avatar
Problem solved - I contacted Pentax (Ricoh?) and they suggested doing a camera RESET in the Set Up and Custom Functions menus. This worked.
k-x, pentax help, pictures, view
K-X Live View question whittaker54 Troubleshooting and Beginner Help 3 08-19-2013 05:53 AM
Does K-01 enable you to disable AF zooming in Live View Basset Pentax K-01 7 02-04-2012 07:54 AM
K-x: Frozen in Live View jaieger Troubleshooting and Beginner Help 6 02-08-2011 06:25 PM
K-x focus in live view? BirdDude007 Pentax DSLR Discussion 2 12-19-2010 09:49 AM
K20D live view does not work mccarvindh Troubleshooting and Beginner Help 2 05-25-2009 11:05 AM
All times are GMT -7. The time now is 04:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
