07-05-2014, 11:50 AM   #1
Spotmatic meter trouble
Hello, I have been researching here on the forum. I have replaced the battery twice, the last with the recommended replacement at 1.35. I have checked the contact and cleaned and still cannot get the meter to budge. Even removed the lens from the body to ensure the mechanism works (it does). Now I don't know which way to go. I read questions and answers from "DigitalDiva" and have went through the steps she took but haven't been bless'd. Can anyone suggest anything.
07-05-2014, 02:24 PM   #2
Eric does repairs on old Pentax cameras & lenses. He is the best there is and very reasonable. Email him a description of what is wrong and he can help.He has been used here on the forum forever....
07-05-2014, 05:12 PM   #3
Just1MoreDave's Avatar
One problem is that a leaky battery corroded the wire from the battery terminal to the meter. At some point, Pentax started using stainless steel for the battery terminal to prevent this. If you are feeling handy, you can remove the bottom plate from the camera and look at the single wire leading from the terminal into the camera. It may be just hanging on with insulation.
It is probably a good idea to send the camera out for service anyway. The stainless steel part is tough to reconnect a wire to. Service can check the shutter timing, redo seals, etc. There are service manuals on the internet, but camera repair is hard to learn on the fly, lots of tiny parts and needs some tools.
07-05-2014, 05:50 PM   #4
Loyal Site Supportaxian
jbondo's Avatar
Even if you fix the circuit, the calibration has a good chance of being off. As those old sensors age, they tend to need recalibration. Sometimes, though, they're still accurate. ( Or if you're on a limited budget, you can always pick up another body with a working meter - they're pretty cheap. PM me if you want one, I have a box full.) Your best bet is Eric if you want it all fixed up proper. Home
07-07-2014, 06:59 AM   #5
FrankC's Avatar
Unless the camera has some sentimental value, then I'd say junk it. For less than $50 you can get another body.
07-07-2014, 08:26 AM   #6
paulh's Avatar
I'm probably stating the obvious, but is the battery installed correctly? Try flipping it upside down & reinstalling. (worked for me!)
camera, meter, pentax help, photography, spotmatic meter
Pentax Asahi Spotmatic F light meter help andrewmaiphoto Pentax Film SLR Discussion 3 01-06-2014 02:22 AM
spotmatic - surprise, light meter issue pixelvandal Pentax Film SLR Discussion 8 10-10-2013 07:34 AM
Spotmatic F meter SeventyCam Pentax Film SLR Discussion 2 06-23-2013 07:05 PM
Questions about light meter on Spotmatic. captmorgan23 Pentax Film SLR Discussion 5 06-23-2013 10:34 AM
question re: light meter on spotmatic f mlynn Pentax Film SLR Discussion 4 09-15-2012 08:20 AM
All times are GMT -7. The time now is 02:38 AM. | See also: NikonForums.com, part of our network of photo forums!
