Originally posted by MarkJerling Do not deviate from the update procedure as posted on the site. Also make sure you download the correct update file - there's a different file for the K-5II and the K-5IIs. Under no circumstances must you use the wrong update file or you may brick your camera.
Copied from update site:
Updating Procedure
Provide a formatted SD memory card for the update software.
The download file is self-extracting. The following file is extracted.
[K-5II] Fwdc216b.bin: This is the updated firmware.
[K-5IIs] Fwdc218b.bin: This is the updated firmware.
Copy the above Firmware file [fwdc216b.bin] or [fwdc218b.bin] to the root directory in the SD card.
If your computer does not have a card slot, you can copy the firmware update file by inserting the SD card into your camera and then connecting the camera directly to your computer.
Insert the the D-LI90 battery into the camera and confirm the battery is full by battery level indicator then turn the camera off.
Insert the update SD card (prepared in step 1) into the camera and close card cover.
Turn the camera power on while pressing the MENU button.
"NOW LOADING" appears in the LCD monitor, and will change to the "PROGRAM UPDATE". At the bottom of the LCD monitor,
CURRENT VERSION 1.00/1.01/1.02/1.03/1.04/1.05/1.06
UPDATE VERSION 1.07
will be displayed.
Press the four-way controller to select "YES" and press the "OK" button.
"UPDATING" appears on the LCD monitor and updating starts.
Please do not under any circumstances switch off the power before the update is completed.
It will take approximately 150 seconds to complete update.
When update is completed, the "COMPLETE" will be displayed at the left bottom of the LCD monitor, then turn the camera off.
Remove the update SD card from the camera.
To check the Firmware version in your camera, turn the camera on while pressing the MENU button.
Check that the version displayed in the LCD monitor is "Ver.1.07"
The camera automatically starts up after about 5 seconds
Mark I finally got it. I was downloading the Firmware to my desktop instead of the camera. I also missed the step to turn ON the camera while holding down the MENU button. Once I did that everything worked like a charm. It took a little longer than 150 seconds though.
