07-07-2014, 07:55 AM   #1
K3 settings advice please
some help please if possiable
and THANKS in advance.
should I be using these on or off
1) Link AE and AF Point
2) AE-L with AF Locked.
one more point, what do others set this at
( Hold AF STATUS 1 TO 4 What do others use,
other settings I would like to no are
1) Exposure mode what do others set this at
I have set Tav mode as that is what I use most of the time
3( Dynamic range settings Highlight correction what do others set this at or what is advised.
4) Shadow correction what have others set this at should it be on at all ( as I use Lightroom and shoot only in raw 0
Sorry for all the questions but I am still learning
Tom G
07-07-2014, 08:50 AM   #2
hcc
hcc's Avatar
I have a K-3 and I started with the recommended settings of PF in-depth review:
Pentax K-3 Review - Recommended Settings - PF Reviews
This is an excellent starting set of settings. Afterwards, experiment and see what suits you best.
07-07-2014, 09:12 AM   #3
QuoteOriginally posted by hcc Quote
hcc
Thanks
Tom g
07-07-2014, 09:21 AM   #4
PePe's Avatar
Points 1 and 2 depend not only on your personal preferences, but also on the situation. I think you should just experiment with these settings to find out what works for you.
Points 3 and 4 may be a bit different. If you shoot RAW (as I do) you are probably better off switching these functions off as the corrections can be done in post processing, if necessary.
af, camera, correction, k3 settings advice, mode, pentax help, photography, settings
Post your K3 AF settings here ! jpzk Pentax K-3 50 03-31-2016 12:45 AM
K3 Interval shooting settings boxcam78 Pentax K-3 3 05-25-2014 05:35 PM
Help me understand some settings on K3 Please Tom777 Troubleshooting and Beginner Help 2 05-24-2014 05:39 AM
K3 exposure settings bscott Pentax K-3 2 04-19-2014 08:55 AM
K3 Focus Settings when using Telephoto lens pearsaab Pentax K-3 3 01-31-2014 08:44 PM
All times are GMT -7. The time now is 06:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
