07-16-2014, 03:07 AM   #1
pictures taking much longer to show up on my camera
Hello everone I just bought a new lens its the smc da 1:2.4 35mm al it takes great picture but it takes a long time to show the pictures up on the back of my camera my camera is a pentax k5 any advice if I need 2 set my camera u different thanks in advance
07-16-2014, 03:21 AM   #2
what a SD card do you use? It may be slow card.
07-16-2014, 03:21 AM   #3
MarkJerling's Avatar
Using a different Pentax lens should not affect the time it takes for a photo to show up on the LCD screen. Suggest you remove the battery and re-insert and see if that fixes the problem.
07-16-2014, 03:30 AM   #4
QuoteOriginally posted by MarkJerling Quote
I"ve done that and even reset my camera to factory set but its still the same and I"ve got a couple of memory cards what work fine with my other lenses could they be some sort of fault with the lens?
07-16-2014, 04:01 AM   #5
QuoteOriginally posted by safc Quote
I haven't encountered this but...have you have the lens corrections enabled ?
07-16-2014, 04:14 AM   #6
QuoteOriginally posted by AldaCZ Quote
Cheers for that aldacz you right it was enabled thanks to you all for your advice I do appreciate all your help
camera, card, cards, couple, lens, lenses, memory, pentax help, pentax lens, pictures
images taking time to show on LCD in manual modes atg Pentax K-5 3 01-21-2014 12:43 PM
Back up sd card pictures to Android phone on the field? lightbulb Troubleshooting and Beginner Help 9 06-24-2013 12:22 AM
K-R Locks up in bulb mode on longer shots jostafew Troubleshooting and Beginner Help 3 09-08-2012 10:59 AM
Advice for setting up a website to show my pictures? Krzys Photographic Industry and Professionals 16 12-31-2011 10:01 AM
Macro snail taking up residence on my hosta plant fevbusch Post Your Photos! 10 07-05-2011 05:18 AM
All times are GMT -7. The time now is 09:13 PM. | See also: NikonForums.com, part of our network of photo forums!
